need help. tranny problem | Ford Explorer Forums
Bullet_9295
idaho falls,idaho
ok, so i just finished doing the motor swap in my 00' explorer xlt sohc v6. after running into a few issue's i now have another.
after the motor swap, i drove her around the block a few times. ran great! i then go into reverse to park it for a wash, try going into drive, and it wont go. now it wont go into any gear. wont even try. i checked the links they are fine and move how they are suppposed to. checked wires and they are fine.
it makes no noises, tranny ran fine before and during the time i drove it around the block. the motor runs fine.
plz help iam about ready to give up.
sounds like it picked its time an nows it, but if u can run codes,
i really dont see how it could have gone so sudden, no noise grinding vibrating, or hesataion in shifting. no cel's. i tried changeing the pcm relay, thats a big no go...
The fluid level is OK?
yes, fluid is actually a little overfilled. it drove fine, then i went to move it for a wash, went into reverse fine, i put it in drive and it just reved. it wont go into any gear...
did you have the pan off the tranny? Maybe the detant level was not in correct position?-
torque convertor bolts sheared off or fell out??
