Need help w/ Window regulator | Ford Explorer Forums
03Mach1
New Orleans, La
03 XLT
2003 Explorer
The front drivers side window went out yesterday. Started to roll it down and it stopped half way then gravity took it the rest of the way down as I was driving. Got it home and opened it all up to figure out what the problem was. The motor still turns in both directions with the switch, there is no grinding sound to the motor so I am assuming it is ok. Reaching around I felt a loose cable that goes from the motor to the pully on the bottom bracket closer to the front of the truck then up to the window on the end closest to the front. I take it at this point I need a new regulator. This is what I was going to order I was hoping someone might have some input on if for one this is what I need and if anyone has used one from this place.
http://www.1aauto.com/1A/WindowRegulators/Ford/Explorer/1AWRG00205/256403
Appears to be the correct one since I was just inside the door. No experience with that seller.
