paul99explorer
- July 19, 2004
- Charleston, WV
- 99 Sport
Ok, I have a misfire that I can't seem to get rid of. I bought my x about a year ago and it had a minor misfire. I immediately replaced the plugs and I could see that one of them was actually cracked. I replaced them and the miss was still there. Since then, I have replaced the plug wires, tried seafoam, cleaned my MAF, etc. There is no CEL/codes whatsoever. There also does not seem to be any arching around the engine (checked it at night with a mist of water) nor does there appear to be any vacuum leaks. I have pulled the plugs out again and checked them. All of them appear to be in perfect shape. No carbon buildup, very little wear, and all of them appear identical, which tells me that most likely the problem is not with any particular cylinder. The only thing I can think of is maybe the coil pack is bad. I don't think there is any surefire way to test it, but I could be wrong. Any ideas? Also, am I overlooking any other possibilities?
