Need help with door triggers | Ford Explorer Forums
darkowy
Chicago, IL
98 Sport
Need help figuring out wires for individual door trigger on my 98 Sport. Right now I have my alarm hooked up to dome light but I want to diode isolate all triggers to avoid problems with dome light. The problem is I can't find those wires. My only info shows:
yellow/black drivers door driver kick panel
light green/yellow drivers rear door driver kick panel (N/A I have 2 door model)
white/purple rear hatch driver kick panel
gray/red passenger front door passenger kick panel
pink/light blue passenger rear door passenger kick panel (N/A I have 2 door model)
Those wires don’t seem to work. For example white/purple wire in driver kick panel shows 0.00 V hatch door closed and opened. I even cut it to see if the dome light will come on and it did. I checked the switch for a hatch door and there are two wires coming out from it. One is ground and the other is white/purple. Now I'm stuck. Any ideas what to do?
