SVO42
- December 4, 2002
- RV Nomad
- 1994 XL
Last night on my way home from work, a few dash lights and the radio flickered when I hit a bump--only happened twice and seemed fine after that. After I got home I did a few things and then went to the store--no problems. Today I go out to start my X when nothings happens. I turn the key on to START and nothing. The radio had switched to being off and was on a default station. It was acting like something had been left on all night and drained the battery.
I got my charger/starter and put it on the battery. Its quick test showed the battery was charged. WTF? It wouldn't crank the starter. So then I set the charger to its jump-start setting (it'll detect the cranking current draw and throw 75 amps at the battery). Then the X fired right up. Not all was still well--the tach wasn't showing anything, and then the CHECK ENGINE light came on. I shut it off and hooked up my code scanner to no avail because it didn't act properly--something wrong with the X? I try to start it again (without the charger's help) and it fired right up, the tach worked, and there was no CEL.
Any ideas about what's going on here? I put an aftermarket stereo in it about a month ago and was **** about wiring it up right. That's the only electrical tampering I've done with it.
