1992 Eddie Bauer
- December 13, 2009
- Walla Walla, Washington
- 92 Eddie Bauer
I have an electrical problem I need help troubleshooting. I have a 1994 Explorer Eddie Bauer 4x4. If I let the vehicle set for 3 or 4 days without driving it, the battery will be totally dead. I have an electrical / power draw somewhere. I did some research and troubleshooting and I found which circuit the power draw is coming from. What I did is disconnect the negative battery cable and connected a test light to the negative battery post. Then I touched the tester to the negative battery cable itself and it lit up. So to find the circuit that I have the electrical/power draw coming from, I pulled each fuse one by one and touched the tester to the negative cable. If it doesn’t light up, the circuit is ok. However, if it still lights up with the fuse removed, then I found the circuit the power draw is coming from.
I have pictures of the fuse I'm having problems with, but I can't figure out how to attach pictures to this post. In my situation, I’m getting the power draw from just one fuse, which is fuse position #1 in the diagram I have in my repair manual. All the other fuse circuits are ok. The fuse circuit I'm having a problem with contains a 15 amp fuse and it controls the “headlamp switch, courtesy lamp switches, radio memory, remote keyless entry module (my Explorer does not have remote keyless entry), instrument cluster, memory seat module (my Explorer doesn’t have this feature that I know of). This diagram is from a Haynes Repair Manual for a 1991 to 2001 Ford Explorer. However, I found other diagrams online that showed everything listed in fuse position #2 also included in fuse position #1 (interval wiper module, wiper motor, interval wiper/washer switch). And another diagram I found also included the master window switches on the driver’s door in fuse position #1.
So what I did today was remove and unplug the turn signal switch, which controls the turn signals, emergency flashers, wipers, and high/low for the headlights. I then tested the circuit and the tester still lit up. So I then removed and unplugged the headlight switch and tested the circuit again and it still lit up. So then I removed master window switch on the driver’s door and unplugged it. I then tested the circuit again and the test light still lit up. The only thing I didn’t unplug yet is the instrument cluster. So now I’m out of ideas.
Can someone advise me what to do from here or where the problem is? Have any of you had this same problem? Where was the problem located? I’m not that great with electrical troubleshooting, which is why I have to refer to my Haynes repair manual and you guys for help. But logically I would assume that if a switch or other electrical component was causing this power draw, the power draw would stop/cease if I unplugged the switch. Am I correct about this theory? I unplugged all these switches (except for the instrument cluster) and I still have a power draw. Any ideas or advice? I’d really appreciate your help. Thanks…
