Need help with extended brake lines for 2nd Gen 2wd | Ford Explorer Forums
321Explorer
Satellite Beach, Florida
1998 2wd Explorer Sport
Hey does anyone know if the Explorer pro comp 97 ranger brake hoses will work witha 2nd Gen Explorer 2wd. and if so who has done it and if not tell me where i can get it. (moving the braket down is not an option (this is an everyday driver)) thanks as always.
Pat
how much lift do you have on your truck?
As of now, F150 leaf packs in. Soon I will add shackles, and if they are not enough, I will have and add a leaf. (Im putting as superlift front lift kit on) When I put the hard line in, I lifted my bumper until the tires were off the ground, and left plenty of slack then. I let it back down and made sure the line didn't kink. Works like a charm. I can probably post some pictures later tonight or tomorrow if you need them.
Maybe this will help:
Thanks for the help buddy, i went to autozone and got fittings and some hard line. I also bought a bender to get it exactly where i need it. Thanks for your idea. Pat
Be certain and get the correct sized wrench and tighten the $h!t out of those connections. Leaks in that kind of stuff are very bad. I flushed my brake line and got rid of the nasty old fluid while I was at it too. Auto Zone has those benders in loan a tool for free.
