ROBinGa
- February 16, 2014
- Ga
- 2003 Explorer XLT 4x4 4.6
I am attempting to take both rear knuckles off to take to a shop tommorow for them to press in new bearings I bought. Passenger knuckle came out completely and was so easy I thought I would be done with whole job in less than 2 hours. I basically followed advice on a thread in this forum but mainly a YouTube video by FordtechMakuloco. I was mostly worried about pinch pins but those came out easily using my air hammer. I have the driver side knuckle disconnected from all the ball joint connections right now but the axle will not punch through the wheel hub. I soaked it in PB Blaster, have whacked it very hard for a long time with axle nut at the end with my 3 pound hammer, I went to Advance and rented a hub puller but it is just chewing a bigger deeper hole into the end of the axle tip and I'm to point where I can't physically turn that puller any longer. I applied heat with the only heat I have -a propane torch. I am at wits end. It's not just stubborn, the splines of the axle seem fused to the wheel hub.
Can I remove the entire axle and get a new axle and a salvage knuckle? I am about ready to think along those lines.
Please let me know if you have experience with a stuck axle and how you solved yours
