need help | Ford Explorer Forums
need help
clean98x
Glendale AZ
1998 explorer
was mudding last night the x was running great then my brother got his 94 x stuck. tried to pull him then mine started acting up. It wont take the gas past 2000 rpm acts like it has a rev limiter. smells rich with cel light came on. I checked everthing made sure nothing was wet or unhooked. I cleaned the maf and iac didnt change anything. any suggestions.
Did you check the air cleaner and intake in the fender?
What are the trouble codes. That would help a lot.
fixed it. plug on the crank position sensor fell off. whoever owned it before me put the metal clip that holds it on upside down so it was really loose.
