roundy1775
- January 4, 2016
- 1992 Ford Explorer XLT
I have a 1992 Explorer, and after a bad snow storm it didnt start. we thought it was the battery seeing as it was seven years old, so we replaced that and i didnt do anything. so we turned to the starter. we pulled it and had it tested and there was all kinds of stuff wrong with it so we got a new one and installed it. it started up but now the starter grinds when the key is in rest position. not when it starts or when it is held between start and run, just when it is in run, like it is trying to reengage the starter.
because it was fine in between run and start we thought it was the ignition switch so we replaced that, but no change. so we replaced the key cylinder. still no change.
we have also tried shimming the starter with no effect. as well as replacing the starter relay with the same outcome.
basically a whole new ignition system except the internal wiring... have no idea what to do next... any ideas?
