mambomonster
- January 26, 2011
- Miami, FL
- 1999 XLT 4x4
New owner here in Miami - picked up a '99 XLT 4x4 with the 4.0 SOHC a week ago. It's in great shape and I've been busy changing fluids, filters, etc. I need HELP with Keyless and yes, I read the sticky thread. I'm also a decent mechanic.
I found the factory code thanks to this forum and had everything working great, everything being the keypad and one OEM remote that I got with the truck.
Now for the problem: I disconnected the battery to clean the cables and let the computer reset after cleaning the MAF sensor. After reconnected and going for a test run, I started to reprogram things. The radio stations and clock are fine. The keypad does not respond to the factory code and I can not get the RAP into programming mode using the 8-cycle approach per the manual. I have tried several times.
Does the RAP go into some kind of 100 mile wait mode after the battery is disconnected? Anybody? Many thanks in advance.
