BadaBingM3
- December 18, 2011
- Las Vegas, NV
- 1999 4WD 2DR Explorer
So looking through most of the threads and lots of google searching, only bushings I can find are for the leaf springs itself. I have new springs and the drivers side rear leaf spring bushing is working itself out of place due to that the rear hanger is offset due to the upper chassis bushing has worked itself out of place and alignment with its hole. So with driving, the action of the leaf spring has slowly twisted and turned the bushing out of place on the leaf spring knuckle and the leaf spring is partially on the bolt as the bolt is supporting the weight half way on the bushing, the other end is partially out. Sorry no picture to describe but you can just imagine the rear hanger is offset and the bushing of the leaf spring knuckle is partially half way out and stopped by the inner part of the hanger. I'm afraid sooner or later the bolt can snap due to holding part of the weight off the bushing. Anyway, to fix, I need to replace the OEM bushing that is up in the chassis where the hanger hangs from. Where can I find them? Part number? I really don't need to buy an entire kit do I? Thanks!
RB
RB
