robert.flake
- November 13, 2011
- Corpus Christi, Texas
- 2004 Explorer XLT 2wd
I think I have a bad front passenger wheel hub.
I have the whirring noise at high speeds (I also have it at low speeds-and it directly corresponds to wheel rotation), I feel a slight vibration in the steering wheel. When I get close to something that will throw an echo back to me (jersey barrier) it kinda sounds like someone running a fingernail across a comb.
I jacked the truck up and rotated by hand the tire and I can feel a very slight vibration through the tire. Took the tire, caliper, and rotor off and can slightly feel what i can only describe as grit or dirty grease inside the the hub assy.
This is definitely a bad wheel bearing right? I don't have the money to throw parts at the car so if i am going to drop 100 dollars, I want to make sure that the problem will be solved.
Also on the other front tire, one of the wheel studs broke off. Are these replaceable or do i have to change that hub assy too?
