Need tailight wiring diagram 97 ranger | Ford Explorer Forums
Nomadster
Canada
97 Ranger XLT 4WD 4.0l
Does anyone know where i can get a tailight wiring diagram for my 97 ranger 4wd . I lost my tailights only...still have brake lights ...signal lights & front parking lights ...# plate light , just no rear tailights . I think the problem may be tied into trailer wiring harness that i never use .
Tks any help greatly appreciated .
D.
I'm no expert
On March 5 my brake lights went out, both sides, I had tail lights but no brake lights. I took the driver side lens off and looked at the lights (no expert) put it back on and now I had no left turn light. I did not touch that light what so ever. Everyone told me to change the switch on the pedal. So I did, Nope not the switch. I went to the back and checked the plugs with a voltmeter and had my daughter put on the brakes and it was putting out higher voltage. Excuse me but, IT WAS MY STINKING LIGHT BULBS. I lost both brake lights, left turn signal, and my left back up lights. Please check your voltage with the bulbs un-plugged and make sure your getting voltage back there.
Hi...found most of my problem , broken & corroded wires from where previous owner hooked a trailer wiring harness up . Why people don't solder & use heat shrink tubing is beyond me . Also found one of the plug in terminals for the left signal is loose; i think i have that fixed now. Anyhow tks for your reply & appreciate the info .
D.:)
