need window help | Ford Explorer Forums
need window help
wrigley_1285
Decatur, Illinois
00 Sport
ok so my truck is slowly starting to fall apart and the latest thing to start going bad is the drivers window. when i first push the window down button the front of the window starts to go down and the rear of it stays up. then i'll have to push the rear of the window down. after i push the rear of the window down it works just fine (up and down) until i put it all the way up and then i have to start all over again.
has anyone else had this problem? if so what did you do to fix it. also if there is a write up on here and somebody knows where it is could you link me. and before anyone says anything YES i did try searching.
I suggest you pull the door panel off and lube the tracks, cables and rollers.
