imp
- November 12, 2009
- 59 Ranchero F250 D'Line
Been here a lot lately, solved "Forced Limited Power" issues, but retain ABS light ON, that seems to have no effect, "VIN Mismatch". Now, a new CEL after a couple hundred miles. Hoping the Gurus here will help.
P0054 "HO2S Heater Resistance, B1, Pos 2"; P0060 "HO2S Heater Resistance, B2, Pos 2". Both throw at the same time. Delete, come back. 153K, so replaced all 4 Oxygen sensors. Old sensor heater resistance was within spec., which said 3 to 40 Ohms, I had 5 Ohms Upstreams, 9 Ohms Downstreams. Drove 120 miles, same DTCs back.
Found an on-line source which made sense, a little. First, I wondered why both banks would go bad simultaneously, two sensors at same time, nah! Harness faults? Unlikely, as PCM looks at the sensors individually. Site said "Intake Air Leaks" a possible cause.
How about this, guys? I'll reveal that in the process of tracking down possible Throttle Body problems, I had the T.B. on and off maybe 6 times, it's gasket (spacer) looked reusable, has a thin white O-Ring on either side, maybe Teflon. That baby might just be leaking a bit? Ordered a new one, not a common stock item around here, nobody had one, O'Reilly said 2 weeks! If no opinions, or facts come up, I'll be back after I install the new one. Thanks fer readin'! imp
EDIT: 2004 Ex., 4.0L "K" Eng. (Flex-Fuel), 4X4, 5R55S
