Derek Greenwood
- May 10, 2010
- Clearwater Florida
- 94 Sport
My X finally needed a new engine so I pulled it and sent the block and so on off to a machine shop. I ported the heads put on some headers and put in a Delta cam with new pushrods. I put it all back together and put it in the car and it leaked oil badly. Well first the powersteering leaked but a new pump and lines fixed that. Then it looked like the rear main was leaking. Out came the transmission and it wasn't the rear main. It was leaking around the long bolt just to the left of the center of the rear of the pan. So the motor got lifted and the pan pulled. Turns out Ford changed the pan sometime in 1994 so the gasket I had was wrong. Ok so put a new gasket in and reassemebled everything and it no longer leaked but the new lifters were noisy. After about 140 miles one was still ticking. So today I pulled the valve cover and sure enough a lifter was collapsed. Thankyou ebay lifters. So I got to pull the heads. Turns out that was a good thing becase while inspecting it I could see that the valve seals were getting beat up. Seems there was too much lift on my aftermarket heads. So now they are heading back to the machine shop for some work so that they will stop hitting.
Now I have to decide if I will clean and reuse my old lifters which were nice and quiet or if I will replace the collapsed one or buy new ones from Ford.
If I had bought it all from Ford to begin with it would have saved me a lot of time a frustration and may not have cost me more in the long run.
