italianbigsky
- February 17, 2011
- Lecco, Italy
- '96 4.0 V6 limited
Hi everybody,
I'm opening this post as soon as I had my 96 limited back after more than 45 days.
Last time I wrote, I asked about the bad noise and shake I had in the front of transmission, we thought it was the torque converter but then at the garage they discovered it was "just" the flexplate. the converter is OK.
Now, after 45 days and about $1,800 (yes, thats' the whole cost of repair here in italy), I drove my explorer and after a few miles, as soon as I reached a decent speed, the OD light started blinking.
From that moment on, it always blinks, as soon as I start the engine, no matter the speed or the gear or the 4x4 mode.
The OD isn't working, it goes 1-2-3 gear but then the rpm stays high and the gear won't ****f into OD.
I'm sure that before I took it to the garage to solve the torque/flexplate problem, it shifted softly and without any problem. The whole transmission has been rebuilt 2 years and 20,000 miles ago. This time the flexplate was broken in the middle, while the torque converter had no damage.
Consider that we don't have a way to read codes here (American things... who knows them?
) and that I don't have money to spend "trying to solve".
What do you suggest? To go there and ask him to fix the problem once again, or do you really think it's time to throw the whole thing away?
Do you also think that the problem could be related to the job he did dimounting and mounting the transmission?
Thanks for your suggestion.
Edit: I called the grage and he told me that trans fluid could be low, because he prefers to stay low when adding fluids. I'll take the car to the garage this afternoon. That's why I asked for your expert opinion, to discuss with him knowing what could be said and could be a stupid excuse.
Trans fluid is strange: I measured it COLD, and itìs very high, well above the hatched area of the stick.
Measuring it HOT with engine idling, it's almost the same.
if this could help for a diagnose...
