Rocket Man
- May 22, 2014
- Salem, Oregon
- 1991 Ford Explorer
Hey everybody, new guy here. I make rockets @ www.binderdesign.com ....I've got a 91 EX that I've had for like 20 years and it has been to all of the big launches including the ones out at Blackrock, NV.
It recently started leaking coolant, but only when warmed up so I took it to Ford where they said it wasn't leaking and then charged me $100. By the time I got it home, it was leaking.
I determined it was coming from behind the motor but could not tell if it was between the intake or head gaskets, so I called Ford for a quote on both. They quoted $2,600 for some gaskets replaced, so I decided to do it myself.
That's when I found this site. This was the first time I've had to work on a water cooled engine, I've always worked on old air cooled VW's so I wanted to know what I was in for.
I did the tear down Saturday before last, no manual, just taking everything off that got in my way. Everything looked really good, so still don't know what gasket was leaking, but the head gaskets looked pristine, so I believe it was intake around the water jacket ports.
I dropped the heads off at the machine shop on Monday for new seals/resurface. Before I dropped them off, they warned me that the heads on these are usually not in good enough shape to reuse. Lucky for me, after inspection he said they were in really good condition, the best he'd seen come through there.
The only wear I could find that looked halfway bad was the rocker arms where the valve stems hit. I surfaced out the divots with a strip sander and polished them out, they were not too deep. Cylinder bores still had crosshatch, barely detectable ring wear. I've always used synthetic and changed @ 3K.
I reassembled last saturday, got it fired up and it ran quieter than it ever has. I'm assuming it has to do with the valve stems not having to settle into those divots, it was getting pretty clicky sounding, now it sounds like new.
Now I'm looking into why it has always idled @ ~1500. Did cleaning and check of TPS, MAF, IAC. Still have the same problem. Decided to do the paper clip method and got code 22, baro sensor. Ordered yesterday, going to pick up today.
Anyway, just wanted to say thanks for such an awesome site, i could not have gotten far without it! The EX is gonna be good for awhile for major maintenance, I might just have to treat her to a new paint job to look as good as she runs.
