New here trying to get a question answered | Ford Explorer Forums
Countryguymike
Barrie ontario
2000 Ford Ranger
I have a 2000 Ford Ranger 3.0L 2wd and had a brake line blow a small pin hole down by the frame on the drivers side i replaced the line and i didnt run the master cylinder outta fluid do i have to bleed all four or just the drivers front tire closest to wear i put the new line on yesterday? Anyone that can help i would really aperieshate the help
I would think just the one line, being it's the driver front.
You can probably get by with doing just one. If I were doing it, I would do all four. The brake fluid should be bled (flushed) periodically anyway. This is a good excuse to do it.
If you bleed one line and the pedal feels good, you should be good to go.
