Should be moved to 4th gen stockMoved to 3rd gen section.
The first thing I would do is check the transmission fluid level and condition. The 6R60 transmissions are sensitive to an improper fluid level and/or having old, worn fluid in them. Many times a transmission service will make many issues go away.looking at 08 explorer 4wd, 4.6 bucking in 3rd gear.
Only 2009 and 2010 models have the 6R80 transmissions. The 2006-2008 V8 models have the 6R60 transmission. They are basically the same transmission with some minor differences. The odds are that the transmission has never been serviced. The good thing is the 6R60/80 transmissions are one of the most reliable Ford has used in their vehicles. How many miles are on the 2008?If a 4.6 engine, then it has a 6R80 transmission. Wonder when the transmission fluid/filer was last changed if ever?
Ack, you’re right. I looked his profile and saw 04, didn’t look to compare in the post.Should be moved to 4th gen stock
sorry forgot about this post. turned out bad trans. ThanksThanks fellas. Just read about the coils elsewhere. Let you know how it turns out
