New Member | Ford Explorer Forums
Mchase
macomb twp michigan
1995 ford bronco
Hi All, name is Mike Chase. I own a 1995 Ford Bronco which my wife has been trying to get rid of for many years. i finally am able to renovate the beast to his former glory. todays problem is heat blows strictly to the defroster and not no where else. Winter coming this must be a priority. Thanks Mike
HI Mike, welcome to the site
If the Bronco's HVAC is anything like an Explorer's then you might have a vacuum leak since the control between Floor/Panel/Defrost/etc are run by vacuum. Pull the HVAC switch panel out and there should be a bunch of colored tubes (not wires, they look like wires but are bigger) coming out the back.
-Follow those tubes and make sure that the plug on the other side is connected to the Blower box behind the dash on the passenger side. (Drop the glove box and you might be able to see it)
-If it is connected, check the plugs on both sides and the tubes for cracking.
Those are the most likely problems.
-Will
Thank You
Appreciate the quick response. will check those lines
