Daddy
- March 1, 2013
- Mississippi
Hello, new member hear. First off let me say thanks for all the help I have received from this forum. I bought an old 1991 Ford explorer that had been sitting up for a while. I am not a very seasoned mechanic and this forum has helped me tremendously. So far, as a newb with no help other than this forum I have replaced the water pump, thermostat, tensioner pullies, starter solenoid, pcv valve, and heater core. I also had to reroute some vacuum lines using a diagram that was pretty much Greek to me. I am still not 100% I got the vacuum lines right. I took a pic of a white plastic, looks like a place/receptical for a vac line, but im not sure. it is on the passenger side coming out of firewall right above what i "think" is the vacuum reservior (black tube/tank shaped container that has a separate vac line coming from a check valve plugged into it. Some of these vac lines were broken/unhooked, and I just tried to the best I could to read the diagrams. Not sure how to post my picture yet. Anyhow, it's cold right now in Mississippi, and I still have no heat. Like I mentioned above, I replaced heater core, and thermostat, flushed radiator, but still no heat. The lines going to the heater core are hot, checked the core itself, it was hot. My thermometer on dash is still reading cold and never moves. Not sure if that has anything to do with it. Again, I appreciate all the help I have received already, but if there is any info one could share with me to figure out this heat deal along with vac lines please do.
