1qwikbird
- July 2, 2010
- Trenton, NJ
- 2001 Explore Trac
The truck is my father's, so I am not the regular driver. If this question is silly, I'll apologize up front. He asked me to throw a fresh set of plugs/wires on his truck for him and I did so today without any real difficulties except for the #4 and the EGR tube crossing right in the path of the plug which made getting the wire off and on (securely) quite the adventure.
Anyway, I go down to my local NAPA get the plugs (Autolites) and wires (NAPA brand?) and after I'm done. I start the truck, all feels fine. She kicks right off, idles nice and smooth. The old plugs were definitley worn as the gap had grown to about 0.085. I gapped the new ones to 0.054. So I decide to rev the truck up a bit and she wouldn't go past 3000k without breaking up???? I started looking for a loose wire at the plug end. Made sure the firing order was good. (Ford musta had a bad day when assigning the firing order at the coil pack, 1-2-3 then 5-6-4 - asking for a problem with that layout) Anyway after much deliberation I pulled the new plugs, double check the gaps, wire connections. So I took it out on the road and it ran like a beast. Pulled strong on the highway, well past 3000.
Being completely unfamiliar with this vehicle I even put all the old stuff back on thinking maybe I was given the wrong wires or something, but even with the old plugs and wires it behaved the same way?
So my question is: Does ford have some sort of saftey rev limiter built into the ecu to limit engine RPM in Park and Neutral. Never encountered such a thing before. There are no Check Engine lights or Service Engine lights on and I even hooked up my hand scanner to pull codes, thinking maybe the light is burnt out, but scanner read clean?
Thanks for any input you could offer.
Chris
Chris
