schoop
- March 28, 2016
- michigan
- 2002 explorer limited
I am praying you guys and gals can help me understand and possibly guide me. I am a 30 year experienced auto mechanic but what im not is an experienced 2002 ford explorer limited, auto 4x4 mechanic. Bought this vehicle 5 days ago with what seemed to be a common howling rear wheel bearing,,,WRONG!!!! Every question i google about this brings me here to many unhappy owners of bad rear diffs. Will be surprised if i dont end up divorced over this purchase as it was replacement for my wife! It is a beautiful looking and running vehicle but WOW the noises that are now coming from the rear. It has a limited slip 373 with steady howl. Starting from a stop, the first noise you hear sounds just like worn out brake pads which then slowly and surely begins to hum and howl at higher speeds. Letting off throttle makes no difference. Inspected wheel bearing in all the common ways except to realize i cant just spin tires by lifting the rear in neutral. I found RR wheel bearing recently replaced and all e-brake shoes removed. I changed rear end lube with the purple 75w140 and added the motorcraft additive to it. Removed abs sensor and cleaned. Thats where i found the thin small metal shavings. Was about to remove driveshaft so that i could freely spin axle to feel all bearings. This is when i realized i could move pinion up and down with a large 1/16" -1/8" play. I stopped right there. I am convinced i have issues in differential. What im not sure of is wherher i have multiple issues or just one big one. Seems when driving and i slow to make a turn it has made big pop noise and felt like it shifted vehicle sideways!! Same popping also seems to happen when backing up and turning also!? Other symptom seems to be if make a u-turn using shoulder of road it seems to lock into 4x4 but then stays in until a complete stop and park, or shut vehicle off and go again!! Can someone please elaborate on some of this or send me a link of exactly what i am to expect from these auto 4x4's please!?? I will be checking here frequently to answer any questions or look for answers. Hoping to here from those who like to right these wrongs as i can do the work. Googling just sends me to the haters of these. Also is there anyway to know if these things have automatically locked other than the feel???? There are no lights that i can see to tell you! Help!!!!
