ROBinGa
- February 16, 2014
- Ga
- 2003 Explorer XLT 4x4 4.6
I noticed the A/C wasn’t blowing as cold as it should in the 03 4.6 so went to grab my trusty recharge hose and a new can of R-134 to top it off. I spent about 30 minutes jacking with that new can of freon and could not figure why the AC wasn’t pulling anything in and my gauge wasn’t moving. Actually I think that taking the connector on and off several times and opening and closing the control valve probably let a lot of freon I did have escape. By the time I gave up the gauge was showing less than when I started.
Then I researched YouTube and found this video describing new freon cans that came out in 2018 linked below. I found the adapter at HomeDepot for about $4 and also can of freon at HomeDepot for just under $5. With the plastic adapter I was able to add 2 cans of freon with my old hose and now A/C is blowing nice and chilly. Yes I know I really need to use a proper manifold gauge set to pull vacuum and test Hi pressure side but I don’t have that gear.
But the point of this is to maybe let others know if you haven’t had to mess with adding freon since 2018 yet that the new cans you buy have been redesigned to have a self seal valve and won’t work with older equipment that pierced a seal on older cans.
