supercj
- July 23, 2008
- tornado alley, KS
- '91 E x p l o r e r Sport
Hello, and thanks for reading and seeing if you can help.
I just put a new 5sp manual transmission in my '91 EX Sport 2wd. Before I lowered it to the ground to put fluid in it I had it shifting into all the gears. However after I lowered it to level ground and put fluid in it, it will shift into all the gears except 1st and 2nd! Even with the engine started it does the same.
It has new: flywheel, pressure plate, clutch, and slave cylinder too.
Any transmission guru's that can help it would be greatly appreciated, thanks so much!!!!
D e r e k
D e r e k
