No A/C, Blower - 2002 Ranger | Ford Explorer Forums
scsummers
La Porte, TX
2002 Ford Ranger
A couple of days ago I got in my car to turn on the A/C; I heard the clutch engage but when I turned on the blower, no air was coming from any vents regardless of whether I chose Defrost or A/C.
I didn't have time to look at it at the time but the next time I got in my truck after running an errand it worked.
It happened a couple of more times but now to the point where the clutch no longer engages and also doesn't blow.
I checked all the fuses and they look OK; I did have the problem in the past where the wire for the O/D selector button on the shifter was shorting out but that was fixed a while back; initially I thought that was the issue but if so the fuse would be blown.
I am guessing a relay? Hopefully tonight I can do some further troubleshooting to run 12V to the motor just to make sure it turns, etc. The motor and resistor have been replaced in the last year or so.
Any help would be appreciated.
