No airflow from the central openings | Ford Explorer Forums
foonzoo
Hi everybody,
For a couple of month, I don't feel any airflow (fresh or hot) coming out from the central openings (neither from the passenger and driver vents).
Precision: the airflow from footwells and windshields are fine.
Any idea ?
Thanks in advance !
F.
Either one of your vacuum tubes came loose or you could be like me and the arm that attaches to the directional control broke off.
Look under the glove box; it's real easy just press the sides in and pull it down; look upwards and towards the controller and turn the directional airflow. You should see a metal arm moving around independantly. That arm should be attached to a plastic piece that controls the airflow.
A temporary solution is to move the arm yourself into the postion you would want it on.
Hi,
You were very close to the problem knifoon, thanks for the tip !
Apparently, the directional control fails. I disconnect the arm and was able to set it up to the right position.
Now the question is: should I change the directional control (the one that set the position between the windshield or the central airflow) ? How can I be sure that this is this particular part that fails ? Is there any fuse to check before ?
Thanks in advance !
F.
