icepickjazz
- February 9, 2008
- Noblesville, IN
- 2004 XLT Sport 4.6L V8
After roughly two years of no problems from my original fix, I heard a snap followed by no air. Another small amount of plastic had broken around where I had drilled. So once again I was faced with this dilemma. This time I decided to try JB Weld and JB Quick Plastik.
I started by using a small strip of metal that was originally a bracket for a closet door. I measured the strip and drilled a hole to attach the actuator lever. I then attached the metal strip using JB Weld (I did try to rough up the area a little bit before attaching. I used a dremel tool as it was easiest to get in the small space.) After allowing my weld to dry I reinforced the metal and plastic area by adding quick plastik... LOTS OF IT all around the area front and back. I let this cure over night and then applied one last round of Weld.
Be sure to give your weld time to cure out. After curing, I used a dremel tool to smooth out the area where the actuator lever attaches.
I have had 0 problems since making the fix!
I planned to insert pics but for some reason the forum won't let me, but I hope my info might be useful to someone out there!
I have same problem. Did you ever figure out pics? I'd like to see theml
