pearsonbe
- January 26, 2005
- Maryland
- 91 XLT
The brake pedal sinks to the floor with little resistance. I noticed the master cylinder was leaking at the brake booster so we replaced it today. However, we could not bleed it because there is still no pressure in the pedal. I replaced the rear lines (hard and soft) a couple of years ago and they don't appear to be leaking. I also don't see fluid leaking at any of the wheels or in the lines under the truck. The section of line to the rear that passes over the tank couldn't be seen. I did not remove the wheels to inspect. With the lines tight at the master cylinder, I also had my son pump the brakes while I looked around the truck front and rear over and under. I didn't see any fluid leaking or dripping.
Tomorrow, I will try to move the truck into the garage and remove the front wheels to get a better look. By the way, I just got the vehicle back from the shop. They replaced the fuel pump, filter, and part of the hard lines. They recommended replacing the master cylinder, front backing plates, calipers, rotors, and pads.
