no codes anymore... still won't idle!!! I need help asap | Ford Explorer Forums
brandon
ohio
'91 ranger
The story is... 98 4.0 ohv ranger, throwing p0171 and p0174 both banks, both lean, changed MAF, still threw the codes, cleared em. Now the codes haven't been back but the truck has gotten progressively worse running and will not idle, lopes real bad. Very inconsitent while running, Fuel Pressure and filter in fine condition. Ive read alot of threads and can't find anyone with my issue yet...
Then I replaced the upper intake gasket(rubber) and the lower(under the fuel rail) as per on the sites. No change after that!! Haven't had the codes come back yet. I am stumped and i need to get back to work, any help/input appreciated. I have scoured for vaccum leaks and cannot find any. PCV or IAC maybe?? I just need another direction to go i am stumped.
I also replace the plugs and wires and no change either
__________________
