mbryda
- June 30, 2000
- usa,usa
- someone
Hello All!
One question I'd thought I'd ask some other people with more experience before I take the truck to the shop and look like a fool.
Yesterday the wife and I were up in the mountains on some nice dirt/gravel/rock roads and I was using 4Lo and Hi. (Man 4WD makes a lot of strange noises!) Coming down one of the hills (not a bad one), truck was in 4Hi and I decided to put the transmission in 1st (we were doing maybe 10-20 tops) to save some wear on the brakes. Put the lever into 1st, nothing - the tach just stays near idle. Put it in 2 and it jumps up a little, but there is still not much braking in the gear. So I just used the brakes the whole way down.
Got to the hard road, switched back to Auto mode and decided to see what was going on. From a dead stop, put the selector in 1 and pulled out. Got up to 20-30 and let off the gas - tach went from around 4K down to almost idle in a couple of seconds - felt like we were in neutral. Hit the gas again and tach started going up until the RPMS matched the speed and we had power again. Put it in 2 and immediately the trans upshifted. Sped up a little and let off the gas and the RPMS stayed there and we had some engine braking. WTF - How can I not have engine braking in 1 - the manual says it provides more engine braking than in 2.
Checked ATF level at the gas station and it was at the 1/2 way mark on the crosshatch, which the dipstick says NOT to add any in the crosshatch area.
Go out this AM (it was cold) and after pulling out of my driveway decided to pull away in 1. Got up to about 20 and let off the gas, there was some engine braking and RPM's stayed up, but not like what I would have expected. When I got to work, I tried the same thing in the parking lot, and the same thing happened - let off the gas and the RPMs started back to idle with no braking ability.
So, before I'm off to the dealer:
1) Is this normal operation for the 5R55E transmission? All the automatics I have ever driven always have engine braking in 1st...
2) Any clues on what could be causing this? Transmission shifts great, crisp and without hint of slipping. Drop the pedal down to the floor and she downshifts right away. Convertor locks up good and everything seems to be shifting/working right. No OD light or Check Engine light, either.
3) Any idea how to best explain this to the dealer?
Thanks for any hints/Ideas/TSB's!
-Matt
-Matt
