Bugmanovski
- October 28, 2012
- Jönköping
So it happened. My 1997 ford explorer doesn't start. Checked fuel pressure and its very low (have no gauge). It just leaks some fuel while pressing the measure thingie on fuel rail. I have measured voltage on fuel pump wire and it gets power for a second or so when I switch the key. I have also taken a wire straight from battery to pump and if I run it like this I get some pressure but only just enough to give a slow flow and low pressure. The ground cable is very black inside. Not shiny like power cable when I tog some isolation of. Could this be a ground issue or is the pump kaput?
