No Lights!! | Ford Explorer Forums
No Lights!!
TarHeel085
And den
Raleigh, NC
'99 Sport 4wd
well i had to re-do my trailer wiring harness tonight and i got everything connected up and soldered together and i start driving down the road and no lights whatsoever but brake lights, head lights, and interior dome lights. which means, no turn signals (short somewhere i know) and also no parking lamps, and also no instument cluster lights or any lights inside that would come on when you turn on the head lights. so i went to replace the parking lamp fuse and the old one was just sitting there, not tight at all so i went to replace it and it wont stay tight, its loose! so what do i do? im stumped on this one, ie never run into or heard of this problem. i need to take the fuse block out i guess, but how exactly does it unclip?
i would try to carefully twist the prongs on the fuse if plastic breaks don't worry as long as the metal portion stays it will work. twist them while looking down at it both prongs face you just bent a little at first
