SCB2525
- August 5, 2006
- Richboro, PA
- 1996 XLT
96 XLT 4.0 OHV, 186k
The oil pressure gauge plummeted to nothing one day despite no noises or sharp increases in temp. So I keep driving it and the gauge keeps fluctuating between normal and nothing. A bit and later, I start to hear a bit of light rattling conducive to low oil pressure, but not no oil pressure. I pulled over and sat for a while and tried it again, and pressure was fine, and the rattling gradually went away. Then it happened again and I kept stopping and going until I got home. I changed the oil out from some Quaker State synth with about 2k on it with 4 quarts of Quaker State 10w-40 dino and a quart of MMO. First, after a test drive, all was well and then it plummeted again. So I've been driving it because I have no choice and its odd. It will go for tens of miles without issue and then randomly do it again for a time, and randomly come and go. It seems the longer I let it sit, the less likely it is to do it for a while.
This has happened before but was "cured" with a simple oil change, which I presumed was a clogged filter. That was a few years ago.
So what are you're thoughts? I honestly can't justify doing anything involving removing the engine, considering it would probably cost more than the truck is worth.
