Bullmastiff9
- December 20, 2006
- Onalaska, WI
- '91 XLT
Hello to everyone! Glad to be a part of this site and hopefully I can help others and receive some in return.
Sorry to say, that I am in need of some help right away. I have a 1991 Explorer XLT with around 115k miles on it. I recently swapped out the transmission fluid. Everything went about as well as could be expected. However, since the swap, I no longer have OD.
I knew the Explorer leaked fluid when I got it, so I checked it fairly often until I bought a newer vehicle. After that, I'm sorry to say that I neglected it. So, when I drove it again, it constantly shifted between 3 and 4. Eventually I rarely drove it and when I did it barely moved at all. I attribute this to an extreme loss of ATF. When I did the swap, I was not surprised to find a near empty pan. After the swap, all the other gears shift smoothly, but it just doesn't shift into OD. I was told this could be caused by loose wires or a broken solenoid inside the pan.
Does anyone have information on how to check the wiring to the solenoid without dropping the pan off again? Or, if I do drop the pan off, what am I looking for?
I'm just not sure how to go about starting this repair.
Thanks in advance for any help!
