no reverse (and other transmission issues) | Ford Explorer Forums
Palmer61
Palmer, Alaska
92 XLT
It started out with the delayed shifting issue when it became cold outside. Graduated to slow shifting into reverse and forward gears (had to wait a few seconds before it would shift into reverse or drive) and only first gear worked with occasional shifts into second and third after very high rpm's. I replaced the modulator = no change. It sat for a couple of weeks and then it would not shift into reverse at all. When I started the engine the vehicle jumped forward a bit (while in park). After shifting into reverse it felt like trying to back up with the e-brake on (would not move at all). I replaced the governor assembly (with the 35mm weight)= no change. I drained the tranny fluid (which I have done regularly) and dropped the pan to replace the filter. There was a good amount of metal shavings attached to the magnet and the filter was black. I replaced the filter and put in new fluid. Still no reverse (still feels like trying to back up with the e-brake on), it still jumps when starting the engine, it drives in neutral (but with the engine off- neutral is neutral) , AND NOW it drives and shifts smoothly in forward gears (except for maybe fouth gear as I only test drove it to 45 mph). Still no reverse! Any answers would be appreciated.
Thanks,
Mike
Welcome to this forum! Remove the square plate that holds the low/reverse servo, and see if the end is chipped. Test the band with a long screwdriver to see if it has bounce. The servo seals could be replaced with the TransTec Viton D ring kit.
is the low/rev servo the one toward the front or rear? and where exactly should I look for chipping? thanks
mike
