NO reverse lights!! | Ford Explorer Forums
NO reverse lights!!
tommyd
Mastic Beach NY
2000 XLT V8 AWD
Having problem locating switch for reverse lights. Is it built in to the shift linkage at the transmission?:us:
I know on my 93 ex the switch was on the transmission but the newer ones i am unsure.
I have a feeling there at the shift linkage on the trany
I have a 2000 ranger
tommy,
not sure if your is the same as mine but on my 2000 ranger the swich for the reverse lights is acualy the netural safety switch on the left side of the transmission. You may be able to go to a site such as auto zone and look that up under DYS. i hope this helps
Correct, the backup light switch is part of the transmission range sensor on the left side of the trans. In fact, the adjustment procedue for the sensor is based on turing it until the back-up lights come one, or something like that.
If you are going to change it, take the opportunity to replace the shaft seal as well. It looks just like a mini-wheel seal, and it only costs a few bucks.
Autozone has them, for about $50. They list it as a nuetral safety switch, although it is really a transmission range sensor.
