no second gear 4R55E | Ford Explorer Forums
meinpa
Pittsburgh,PA
1996 EB 4.0USA
I get a codeP0756 and when starting out first is fine, then trans tries to shift into second but revs high and goes into third.
dropped pan fluid ok shift sols look oh, wires, etc. seems like the bands are pretty loose, anyone have the torque specs on them, and can a bad band cause the code to pop up? Thanks
Thanks for the thread. I know the bands need adjusted and I will check the sol's resistance after church today. I'll get back to you.
OK.. went to adjust the intermediate band... ran the screw all the way in almost.....snap... band is trash. I have the lift, equipment and know-how.. I ordered a rebuild kit and new bands... will be in by Tuesday. I yank and rebuild test all the solenoids and replace the internal harness due to 120,000 miles... This is my son's car.. besides his 01 Mustang GT. I'll get back... if anyone want's pics of the rebuild steps, let me know..
give me the steps you want.. I'll take the pics and show the steps as you see fit... Matt
You could make a how to thread. We don't have much on the 4R55E.
I don't have an ASTG manual on the 5R tranny, but I was under the impression the valve body from the 4R and 5R were the same. I have never compared them side by side....correct me if I'm wrong.
...........jjf
The specifications on the 4R are a little different. The EPC has a green screen, and the 5R has a red screen. The newer solenoids use inductive signature for the PCM. The shift solenoids are the same. It's possible that there might be other things which are different.
