Noise when going over speed bumps | Ford Explorer Forums
Z400Pilot
Tucson, AZ
2004 XLT 4.6
I have a 2004 XLT 4.6 4wd with 56,000 miles. I noticed two days ago that I get a moaning sound when going over speed bumps that sounds like it is coming from the front end. Sounds like a bearing perhaps. Now I started listening when entering or exiting parking lots with a steep lip. I definitely hear it when the left front wheel articulates.
Any ideas?
How expensive to fix (I would do the work myself) ?
How hard to fix?
Thanks for any Help.
I had a similar problem I was getting a womp womp noise when i went over bumps that required the suspension to compress more than usual and I replaced the stabalizer bushings which were about 12 bucks total. If you want to try this before you spend money spray some WD-40 in there I did and it went away for about two weeks before coming back
does your steering wheel feel loose?
I had my upper steering intermediate shaft replaced and the noises/ loose feeling steering wheel went away. It is the shaft you can see that goes into the firewall on the drivers side/ has a knuckle on it.
almost definitely sway bar bushings. Don't bother lubing them, it will come back in a week or two. Replace them and be done with it.
I will have to look at the sway bar bushings. It seems like low mileage to have sway bar bushing problems, but with two of you saying the same thing I had better check.
jakedrew - steering feels tight so I don't think that is it.
I will look at it this weekend and report back.
Thanks
The bushings wear out, especially in harsher climates, like really cold or really hot. I see you are from the desert so I m sure that they have just dried up. The factory bushings are not the greatest IMO but I know that if you go to a NAPA or any other brand bushing that they are way superior to the OEM ones.
But if your looking to lube them, WD40 works but try to find a Silicone Lube to try instead as it will last a bit longer. For me it last 6-8 months and I live in Canada. :)
Good Luck.
I got the moog ones
my sway bar bushings went out a little over 40k miles. But i live on a gravel road too and they were pretty dirty.
I sprayed them and the sqeek went away, for a week like others said.
They are cheap enough just to replace them and be done with it. I replaced mine with ford ones. been fine for 20k miles now.
I appreciate all of the help. I will be looking at them tomorrow.
