hazmat456
- May 27, 2007
- tomah wi
- 1997 mercury mountaineer
so over the weekend the wife and I decided to take a drive. It was upper thirties lower forties,sleet/snow every once and awhile. About fifty miles into the trip the wife said she was getting cold. the thermostat was all the was up and the blower on low. I tried to turn up the blower,no air flow, well very little,fan speed did increase though. I tried switching from floor to defrost, no change, tried mix- no change nothing made a difference air, max air , nothing much out of any of the vents. I stopped at a gas-station and poked around, everything seemed to be in order, I could hear the servo working as I moved the dial, the fan was working could hear it change speeds, it was like something was blocking the air-flow. So finally , turned off the truck after a restart everything was back to normal. During the same time the wipers would pause for half a beat in mid swipe every so often always in the same spot. Dose anyone have any idea what happened? when it happens again I would like to know where to start looking. I don't really think that the two things are related. any suggestions would be appreciated.
Matt
1997 mountaineer 5.0 164,000
Matt
