O/D flashing and tranny problems | Ford Explorer Forums
muskie10
Ohio
95 EB 4x4
ok heres my prob. the truck runs fine except for it shifts hard either accelerating from 2 to 3 or decelerating from 3-2. it clicks or sounds like u ran over a pop can. took it to aamco and paid for a diagonstic and they didnt tell me anything. but wanted to tear the transfer case around. what is up with this thing?
When does the O/D light start to flash, as soon as you start it up (cold engine), or after you've been driving a while? My '97 Explorer was doing somewhat of the same thing. It drives fine until it warms up after a long trip, maybe 40 - 50 miles and then the O/D light starts to flash and the shifts get really hard. I also have a clunk that sounds like the torque converter isn't locking up. Took it to my local tranny shop and they said that the torque converter was in the very early stages of going bad and I needed a tranny rebuild. I'm gonna try to replace the solenoids on the valve body and see what that does. Take a look here for more valve body info:
http://www.explorerforum.com/forums/showthread.php?t=140987
A long thread, but a TON of useful info!!
Good Luck, and welcome,
Brad
the o/d light, like seconds after the truck starts
man the o/d light comes on as soon as the truck starts. not even 3 seconds after ignition is turned.
The flashing O/D light is just like a flashing check engine light, I'd try to get AAMCO to give you the codes that they found and do some more looking around on here.
Brad
