cjvervaet
- April 8, 2023
- Howell, MI
- 2007 Mercury Mountaineer
OK, here we go...
I'm stumped and I'm leaning towards an electrical issue. Here's what is going on.
This is for a 2007 Mercury Mountaineer Premier that has the 4.0L V6 and she's 217000 miles young.
The other day I had a error code for the O2 Sensor 01 on Bank 01 P2196 that was thrown, indicating that the sensor was stuck on "rich" and code P0132 indicating I had high voltage (1.3 volts on my scan tool).
I swapped out the sensor, for both the upstream and downstream sensors. When I fired it up, I didn't see any voltage at all being registered, and it was throwing code P0053 "Heated O2 Sensor Heater Resistance". So I had thought I had a bad sensor, I purchased some on Amazon, however the downstream sensor that I replaced was working fine and registering around .7 volts (while fluctuating) and that also matched the Bank 02 Sensor 02 readings when the engine was nice and hot (Catalytic Convertor Temp around 1200F).
So I shot down to AutoZone this morning and bought the OEM Bosch upstream sensor and installed it this morning, also checking to see if there was any evidence of corrosion or a bad wiring connection.
As soon as I hooked the battery cable back up and fired up the engine, I saw the voltage spike to 1.3 volts then settle down to 0 volts. It stayed at 0 volts during the test drive and never moved. I then got codes P0053 "Heated O2 Sensor Heater Resistance", P0135 "O2 Sensor Heater Circuit (Bank 01 Sensor 01)", P2195 "O2 Sensor Signal Stuck Lean Bank 01 Sensor 01" (which is the opposite from the "rich" code that started this whole project).
So after 2 new sensors, and 1 of those being an OEM part, I started to check more readings.
Maybe the wiring harness has a crack or is damaged somewhere? Or the male connection is damaged? Or maybe the purge control valve is stuck open?
Any help would be really appreciated.
- I removed the Mass Air Flow Sensor and cleaned it with alcohol and also ensured that the wiring harness wasn't cracked.
- I removed the spark plug from Cylinder 01 on Bank 01 and inspected it. It looked fine, no evidence of charring or running a lean/rich mix.
- I checked the fuel rail pressure, it was reading around 40 PSI at idol.
- I reinstalled the MAF and checked the CFM readings and they look like the sensor is registering CFM just fine, fluctuating up and down depending on the throttle commands.
- I checked the fuse in the engine compartment for position #42, and that was fine as well.
- I also checked my intake pressure and it looks normal, reading around 5 PSI at idol.
- Air Fuel Mixture readings are around 14.7, which I believe it also at normal levels.
