obd 1 code reader | Ford Explorer Forums
obd 1 code reader
jared ajlouny
san jose, california
'95 XLT 4X4
i am looking into buying an obd 1 code reader, like the cheap ones from walmart. before i buy one i want to make sure that it will be able to read all codes. it will be able to read the codes when the check engine and od off lights flash???? just making sure? thanks
nobody knows?
I've got one that I bought to read the codes on my old 89 Mustang GT. While poking around the engine compartment on my 95 explorer sport, I noticed that they both used the EEC-IV brain-box so I slapped my code reader to the connections and pulled the codes in the key on engine off mode. The only difference was that the explorer uses a 3 number code while the mustang used a 2 number code.
So I guess the simple answer is, Yes
I've always used a $3 voltmeter as an OBD-1/EEC-IV code reader.
please explain?!
www.dalidesign.com/hbook/eectest.html Might want to review these instructions, even if you decide to get one of those more expensive code readers. I'm not sure how good the instructions are that come with those code readers.
