In order ( I hope):
-5.0 - I'm quite sure...email him. He is very good responding to sales and support questions.
Real time log – great!- start the car, hit the record button, drive around, then play it back at your leisure (in front of TV? …whatever?) View and/or graph component parameters. Those that pass and fail are indicated.
Helpful? - I thought so. I've used it on my 97 X and other cars. It was invaluable. Keep in mind, ODBII is not "absolute" and the codes are not always the "end all answer". With "no starts" it can be useless. The process can require interpreting and additional reading to get at the problem ... I know I'm still going up the learning curve. I think you will learn to appreciate THOSE who really know ODBII.
My O2 question below may be a limitation with the software ...but it also may be limitation with others. Don't know. Ford does have many propriety codes. I know some additional codes are being released as a result of a recent court case. Pxxxx seems to keep abreast with updates and on top of them.
-Laptop? good question... I thought updates (for Fords and others cars) would be easier load to keep current. Do you get any updates with non PC based code readers? Don't know.
Personally, I know my way around computers.
I also had a few old laptops lying around. It's "DOS" based, so it will run on any laptop - even if they’re “old as dirt” e.g.- runs on WIN3X.. The laptop batteries should be good, if you want to go through a driving cycle.
If the laptop breaks...load the software to another. You can get an old laptop, often for nothing or at a PC show for $100.
I put all my "stuff" right on the HD - DB of Ford codes, articles, reference stuff as well as the CD Ford Repair Manuals. You can "port" the program and logs to a desktop, like any other PC file…no hassle… no interface programs or special adapters to lose.
Laptop sounded good to me.
just my thoughts
