I need some advice on my friends 1999 Ford Explorer.
Recently its been making some odd grinding and binding noises coming from the passenger side wheel well. I took the wheel off and there seems to be lots of movement on the hub. Brakes look good and operate fine. Other suspension parts surrounding it are not loose.
My assumption is that it could be a wheel bearing but thought I'd ask around first.
When replacing a wheel bearing is it required to replace both the fronts or can I just do the passenger side? I'm assuming that with the wheel bearing I'll have to buy a whole new hub that already includes the bearing. Correct?
