sport97
Elite Procrastinator
- September 25, 2008
- connellsville pa
- 1997 sport SOHC 4.0
I've been looking at tons of mufflers. I've kind of been turned onto the dynomax super turbo recently. It's supposed to be relatively quiet, its cheap(only 45 bucks), and stainless...(now I don't see where I saw this, maybe i've been looking at too many mufflers).
My concern is there is no dual inlet/single outlet like I need for bolt in application(unless this is a reversible muffler) . The only center to center is only 3" pipes. I plan to run stock 2.25". The one people seem to use is the offset inlet/center outlet. Part number 17731.
How do I install an offset inlet? Do i first use a Y pipe then a bent piece to meet up to the inlet, or is there an offset y pipe piece?
I'm on the fence about clamping it myself, or just having a shop weld it up for me because I off-road, and mud and water could find its way into a clamped system. I assume a shop would find a way to get the offset inlet to work on a SOHC, as others have it.
Thoughts?
http://www.dynomax.com/mufflers.php?muffler=superturbo
Thoughts?
