kikboxr1
- September 10, 2004
- Atlanta, GA
- '03 Mazda B3000
Is there any way to test the temp sensor to see if it is bad or not? Mine is showing about 20 degrees cool constantly. The sensor is basically a resistor that varies with temperature right? So there is a negative flow between the black/blue and black/white wires, and the sensor in between changes how much resistance it throws in. Is that how it works? Anyone know what kind of readings I should get in 80-90 degree weather?
I read on an old post on RPS that there is some thermo-resistor thingie I can get at radio shack that works the same as the factory sensor. Can anyone provide more info on that? I have the sensor in the interior so I don't think it matters if it has a protective housing or not.
