chuyalmaraz
- August 16, 2010
- Toluca Mexico altitude @ 9100 ft.
- 99'Explorer XLS OHV
I need help, my 99 XLS V6 OHV Ford explorer oil I am afraid to drive it around the gauge goes flat when engine is hot and check gauge light goes ON (not check Engine Light is on), I am driving in Texas, the temp is horrible hot right now , I changed the oil to a Synthetic few days before to 10-30W oil then this issue came up almost right after driving it for 200 miles, I added a oil stabilizer but nothing, questions:
1.- Should I change the oil and filter again and see what happens?
2.- May be the oil filter is bad ? or the oil pump is bad ?
3.- how should I know if the Is oil pump is working well or not or is good or bad ? when is cold the gauge is normal and no red light check engine cones on.
I drove it for a little while about 5 miles until gauge went flat again when is hot but nothing is wrong with the truck, but I am afraid driving it, how should I know all is well?
4.-lastly when the truck is hot, the intake makes a horn loud moose call noise. Intake idle valve went bad may be?
Help I need to fix it before I go home I have 10 hrs. ahead of me.
